Blue Fin Help
  • Blue Fin Help
    Hi ,My VXR has a milltec K&N panel Filter and blue fin stage one, do I need to upgrade to a stage two. Am I missing out on anything..? In such case how do I go about obtaining the blue fin upgraded. If anyone can assist that would be great.
    try phoning or emailing superchips or who you got the b/f from
      where did you get it from?
        if you have a full exhaust you will need to run stage 2 to get full power etc contact your tuner/supplier of bluefin
        GONE BUT NOT FORGOTTEN!
          got the blue fin from cobbs on here, still have standard cat but milltec pre cat and the rest of the system
            you need the cat to upgrade to stage 2 !!
            www.thevenuelondon.com / www.myspace.com/fatboyateallthepies
            the owner of the first zaffy detailed by vxrmarc and also the owner of the first bus sm'd by vxrcourt3
              as above so stick to stage 1 for now
                well if cobbs is anything like thorney you plug the blue fin into your pc with the software provided and if like thorney they down load the stage codes you want to your pc and into the blue fin.
                  What will it do if i upgrade to stage two without sports cat will it be down on power..?
                    not sure probably cause you problems, as the standard cat is very restrictive compared to the 200cell in the milltek, so the boost/fuelling etc set on s2 might be different to s1 therefore causing issues, hth
                      thanx mate
                        Get the Sports CAT and you can then go onto a stage 2 map - More go gooes
                        My VXR from Start to Finish
