Setting the time??
  • Setting the time??
    I have an aftermarket headunit fitted but need to change the time on my in dash display. Is this possible??
    Burg #332 - 270 bhp - gone
    Mazda 3 MPS - 490 bhp - gone
    Audi S4 - MRC stage 2/490 bhp....so far
    i was reading that here already - it is possible with TECH2 in service or - change the head unit - set the time , and than put back the aftermarket head unit...
      I was hoping that I wouldn't need to put the old h/u back in.
      There must be another way.
        no other way unless you have steering wheels controls or change to oe h/u
        GONE BUT NOT FORGOTTEN!
          I do have steering wheel controls
            i meant with the new after market h/u you have. if you have the steering controls working with that via your new head unit then you can do it from there otherwsie oe unit mate
              I do have the steering controls working with the new hu, also have the track name displayed on the in dash screen.
                so if you have the styerring ocntrols working with the new head unit, you should b able to set the time via the steering controls, consult the manual
                  changed mine using the clock button next to the display unit
                  Arden Blue Corsa VXR , 18" anthracites, Quaife LSD, AP VXRacing 4pot brakes, KW Variant3 (40mm drop) & Uprated Fast Road Geometry Setup, larger intercooler, 3" Nurburgring exhaust conversion, ITG panel filter, Nurburgring front & back splitters, colour coded roof rails
                      Don't know if it helps but here's the Connects2 instructions on how to change the clock from the steering wheel controls. This is the one I have on mine and I know it works.
                        woow dont know that from the steering controls i can go to settings... will try that on me corsa tomorow, thx mate !
                          Thanks mate, I had already sorted it by doing a bit of fiddling.
