reversing light fuse?
  • reversing light fuse?
    does anyone know where the fuse is for the reversing lights. had a look in the manual but it don't tell you
    martyn
    Tech2 Diagnostics
    Theres 3 fuse boxes aint there?
    2 under the bonnet one in the boot area somewhere? Probably in the boot?
    Clique #14
      i have checked the one in the boot. the one in the front is for all the engine ***** i think. just really dont want to take my car to vaux
      Tech2 Diagnostics
        I'm guessing your reverse lights don't work then?
        If so, it could be the switch in the gearbox. I had one of these go on my old Corsa C. takes seconds to change but Vaux did it under warranty.
        The mechanic tested this by taking the plug off the switch and i think he shorted the terminals so that the reverse lights were permantly on. This proves that the fuse and bulb are still ok.
          no buddy only passenger light works. the drivers side fails to light up
          Tech2 Diagnostics
            Have you done the mod that gets both to light up then?
              maybe a silly question, but have you checked the supply on the terminals in the light?
              Whats next?!?!?
                Oops... My bad
                Its the rear fog lights i'm thinking of.
                  Try phoneing your dealer first most prob very simple job and if it is a fuse they can tell you where to locate it.
                    yes buddy totally dead
                    Tech2 Diagnostics
                      will ring them first thing in the morning and see what they say
                      Tech2 Diagnostics
