The offsets are usually stamped onto the alloys dave, but i think it's on the hub side so you would need to have the alloy off, should be along the lines of ET (then number)
corrrect me if im wrong, but the majority of my alloys have been like this.
the burg wheel is 18x 8 i think but what about pcd and off set anyone help.
wheel pcd is 110mm
wheel offset for 8j x 18 is 39mm.
might have to double check the wheel offset on the rim as the burgs are suposed to have a wider track than standard vxrs.
...superior horsepower through knowledge,good design and maximum efficiency
