got me rear anti roll bar today (bargain from courts) can someone explain to me the soft,medium and hard setting and which one is best for everyday use
cheers
well to be honest, there are 4 settings, mine is on the harder of the middle settings and its great. the instructions will describe which settings produce what characteristics.
From memory, the softer settings allow more understeer, where as the hard settings allow more oversteer, I could be wrong though.
Your right on there matey.
I run mine on the harder middle hole. Have been tempted to run the strongest setting from time to time but stay with the 2nd strongest. Otherwise wet performance can be a bit scarey if faced with an emergency brake situation while turning
Just had mine fitted today. Not had chance to test it properly. Car did feel a little tighter driving home though. Got mine on the 2nd hole down from the front of the car.
