hey guys. not had my vxr long, obviously noticed no temp gauge. would like to know the water temp, or engine temp which ever the temp gauge is on everyday cars? can it be brought up using the trip computer, also if not would i need to fit a temp gauge, many thanks daz
a bit confused help!!!!!
look through the "how to section" .. there is a way to set the computer to do all that for you !!! .. or use the "search" function .. promise .. it does work !!sigpic
www.thevenuelondon.com / www.myspace.com/fatboyateallthepies
the owner of the first zaffy detailed by vxrmarc and also the owner of the first bus sm'd by vxrcourt3
i was talking about on here !!sigpic
Turn the stereo on then press and hold the settings button for about 5 secs until you hear a beep(Audio will appear on the comp screen) then press the bc button I think 9 times and you will see on the screen v=speed in kmh and o=coolant temp..
