Breather Hose
  • Breather Hose
    How do you get the standard vauxhall black clips off as they are as hard as hell!
    Want to replace the standard black hose with my new red courtenay one, I have the jubillee clips to put on but I cant get the black ones off!
    Also whats the application to paint the stainless steel pipe red?
    Andy
    use pliers for those clips mate it is tricky as hell and once they are off you will need mole grips to get them back on but use jubilees much better.
      if you know anybody who does powder coating andy get it done that way then it will last longer than paint but i would get some paint that is good with heat prime it first then top coat better off with spray can's though to get the better look mate ,
        Ta.
        Needed a new silver pipe with my hose kit as the hole was too small when I was fitting all my new hoses! so courtenay are sending me a new silver pipe and jubilee clips for my breather hose!
        Can you get the primer from B&Q?
        Andy
          you should be able to get some red oxide in a spray can will dry really quick so dont put too much on at once ,give it a couple of coats
