still cant get this thing to work, there is one pink wire with the end showing looks like it may have come out of a block connector any ideas anyone?
parott bluetooth trouble
Originally posted by corsasrisilver View Poststill cant get this thing to work, there is one pink wire with the end showing looks like it may have come out of a block connector any ideas anyone?sigpic
so that wire is ok to leave hanging out? does every block connector need connecting into another or is it a case of if there is two that join then theyre meant to. it dont seem to power up for some reason when i plug it in or do i have to do that blue wire to ignition firstAstra vxr mk2 with stage 1 EDS remap
Originally posted by corsasrisilver View Postso that wire is ok to leave hanging out? does every block connector need connecting into another or is it a case of if there is two that join then theyre meant to. it dont seem to power up for some reason when i plug it in or do i have to do that blue wire to ignition first
you need to plug them all in!!! and you got to wire the blue to a livesigpic
so plug all the connectors in that will fit together , and before any power will show do i have to connect that blue ignition wire up?? hows the blue one connected again and how do i get to under the fag lighter?Astra vxr mk2 with stage 1 EDS remap
Originally posted by corsasrisilver View Postso plug all the connectors in that will fit together , and before any power will show do i have to connect that blue ignition wire up?? hows the blue one connected again and how do i get to under the fag lighter?sigpic
