Induction kit??
  • Induction kit??
    Hi has anyone had any problems running induction kits on the cars? my reason for asking is i've spoken to a few people now and all have said they suffer with the air flow meter??
    My car has a K&N panel filter and after looking at it i didn't think is was very good, so i went to B&Q and got some large flow pipe which you use for tumbledryers, i removed the front grill and mounted it to the mouth of the air feed pipe.
    It's now like a force feed air system
    What you think?
    Also i was looking at buying the dbilas flowmaster are they any good? and do they suffer with killing the air flow meter??
    http://i210.photobucket.com/albums/b...R/P1020830.jpg
    http://i210.photobucket.com/albums/b...R/P1020829.jpg
    you have given it a cold air feed you mean? induction kits usually suffer from heat soak (open cone filters) so a cold air feed is a must, with a panel filter in the existing box shouldnt be much of an issue
    GONE BUT NOT FORGOTTEN!
      btw the killing of the air flow meter or amm has usually been either an issues with filters being over oiled or just an issue with some standard cars (no filters added), pot luck really
        K&N run dry
          yet once the air, flows from the air box to the turbo it goes over the top of the rocker cover? this is hot would the heat not effect the air feeding the turbo?
            Originally posted by VXR Matt View Post
            K&N run dry
            my k&n came pre oiled (panel filter)
              oh dear ive just oiled my k&N up as it was dry, should it be dry then?
                i think this is why soem people go for the cdti conversion to have a more direct air flow but i think the standard setup with a panel filter is good enough i know mosts stage 3's run this with no issues
                  did your k&n not come with a sticker on the filter telling you that it was pre oiled (on the plastic wrapping)
                    it doesnt matter how hot it is before it gets to the turbo as it get so hot in the turbo it will heat the air anyway. it needs cooling between the turbo and the inlet thats why they have intercoolers fitted.
                      http://www.vxronline.co.uk/forum/sho...ht=cdti+airbox
                        Bit of a read for you - based on the Z20LET but same principles
                        http://www.zlet.co.uk/Induc-Mod.htm
                        Astra
                          Car had it fited when i got it, so not sure. All i know is most K&N filters need to be oiled.
                          Im a massive NEWBI to these cars sorry if i sound like a D**k just trying to find out whats best for my car
                            K8N filters as far as im aware are pre oiled, the only time you need to re oild is after you have cleaned it there is a how to on cleaninf filters
                            http://www.vxronline.co.uk/forum/showthread.php?t=26284
                            ignore the dbilas bit the filter process is the same
                              - good find
                              Astra
