Gap on NGK Iridium Plugs
  • Gap on NGK Iridium Plugs
    Does anyone know what the NGK Iridiums gap is nominally set to?
    I appreciate that these plugs have a pre-set gap but checked mine before installing them today and they are all different :?
    Two of them have a gap of 0.75mm and one of them had a gap of 0.8mm and one was slightly larger still
    I don't want to install them unless I know that the gap is set correctly.
    Andy
    drop 1 of the tuner's or andy16v a pm they should be able to help you mate
      0.05 of a mm is nothing to worry about mate.
      i presume your talking about normal plugs and not iridium ones as you cant alter iridiums
      stage 2 vxr
      [email protected]
        Re: Gap on NGK Iridium Plugs
        Andy
        should be .8 but dont mess with them the std plug is.10
          Well, set the gap on the NGK Iridiums to 0.8 and installed them yesterday morning.
          The improvement was immediately noticeable:
          Smoother Idle
          Better pick-up at low speed/in high gears
          Smoother engine across rev range
          Revs more freely and cleanly to red line
          Better economy (+2mpg!)
          Considering there was nothing wrong with my original plugs (or my cars' performance/engine manners) the difference is quite marked.
          Well worth the £32 IMO.
          Andy
            Smoother Idle
            Andy
            Thanks for the info nutter, i was considering having these fitted on my first service at thorneys, but now you have made my mind up! , i will definately put them in
