cutting and joining the ignition wire for cig lighter
  • cutting and joining the ignition wire for cig lighter
    Originally Posted by corsasrisilver
    cheers mate so i do this
    remove oe headunit
    unclip the big black block connector
    connect parrott wire loom to that
    connect up any other block connectors that go together on that loom
    switch fuses round in the loom
    undo 2 screws, lift up gear gaiter surround
    cut black wire and join in blue
    job done?
    i cant kill the car can i lol
    bump
      can one simply cut the cig ignition wire and join the parrott blue one to it with electrical tape?
        Just use one of these...
        http://cgi.ebay.co.uk/Blue-scotchlok...742.m153.l1262
          i will eventually just thinking for now. will cutting this cig ign wire hurt anything in car apart from the cig lighter comin on off if anything went wrong?
            what colour is the ignition wire i need to tap the parrott into i got the cig lighter out there is 2 sets 2 wires together (red and black ) and then a single wire (black only ) which do i cut???
              bump
                if your not confident in doing it yourself dont bother just pay someone to do it
                GONE BUT NOT FORGOTTEN!
                  i can do it got it all in bits now just need to know which wire is the ign one , is it the single black one or the other one paired with a red one
                    read your own thread!!!
                    Originally posted by vxrdave View Post
                    the box wiring just plug in to each other you cant get it rong as all the connecters only connect to the right bit the live feed you will need to join yourself by either soldering or crimp connector or at last resort scotch lock. The black wire is the one you want from the fag lighter on the burg its wired to the bulb for the ilumination.
                      ah cheers im just gonna tape em together tonight then sort out some crimps later napa said screen wont power up till i got ignition wire done to cig lighter doh lol
                        OMG this sounds like a recipe for disaster!!!
                        Is there no one in Corsasilvers area that can help him.
                        He needs a testlight, Soldering Iron etc etc.
                        Please do not use scotchlocks, they are ****!!!
                        Where are you again?
                        I feel so sorry for you I might have to just drive there myself.
                          This is worrying me
                          Safest bet, get a meter switch it on at volts dc, attach ground terminal to chassis of car (or earth wire), attach live terminal to wires in question, turn on ignition to test, whichever one shows 12volts when ignition is on is correct one, job done safely.
                          By day car and bus wirer thingy man.
                          By night maniac VXR driver.
                            Test light is not the best Idea with a canbus system which I think the Corsa is (could be wrong, if I am I appologise) test light would show voltage but could be less than needed.
                              he has a burg
