boost hose
  • boost hose
    Right when I have 3 or more people in my car it will make a noise when I change gear like
    woo wooo wooo woooo like that Smokinvxr told me last time it was my Hose and he was right
    This is happening a bit now and its really annoying I was in a middle of a Play with a Audi S3 and all of sudden lost the power which is annoying but anyway
    Is there something I can do to fix it
    The main problem is from the Fuel Reg you have that Black 90 degree pipe which connents into a Small hard black hose and that pops off I find
    Is there anything which you can do I notice that there is no Teeth like on the T picese on a dump vavle
    superglue it on jobs a gooden or fit the newer hose ends there green.
      where can I buy the green end then
        vauxhall.
          Green end I dont understand what you are on about
          Is it the green 90 degree pipe from the fuel reg or the hard hose that connects to it
          If I call them what do I ask for
            Its the black rubber 90o bends that go on to the black plastic vac tank from the thin hose.
              just glue the old one on.
                If I glue it on I will do it wrong and prob block it up
                  lol its superglue only nees a spot.
