Milltek Help
  • Milltek Help
    I want to fit the Full Milltek system but funds are tight due to final payment for holidays.
    If I go for the Cat back option, would this give me any improvement in power and give me that Millteck exhaust note, or should I wait and save for the full job???
    What should I expect to pay as I here prices vary
    Or is there an alternative
    Thanks All
    Don't know about the power details but here are some costings
    Turbo Downpipe £240.00
    Hi Flow Sports Cat Assembly £420.00
    Cat Back System £425.00
    Full System £1085.00
      If funds are low at min do it in parts the Turbo Downpipe £240.00 first helps a lot then Cat Back System £425.00 then the cat. also the only bit of the exhaust thats VXR is the back box the rest is same as mk 4 astra turbo so you can get a Turbo Downpipe for £150 if you dont mind the make.
        Turbo downpipe. £150 from regal, possible 5-8 bhp increase
          If funds are low - try Magnex or Scorpion...both do decent systems for the VXR
          The truth is out there ...
            Im in the same dilema mate! I just fitted c/s turbo downpipe and what a difference just that alone makes! I even occasionaly get a pop or bang from the car now which is nice! Very race car like! The c/s downpipe was £190 delivered!
              Does the CAT back system have the jet fighter sound I've seen on Youtube under accelration?
                no thats just my car
                i would save up and get it done all at once otherwise your back and forward to garage and they will charge you everytime you go , so it will work out dearer , get the plastic out and sod the holiday
                  aye!
                  you may do it in bits and be dissapointed. id save up then you got summit to look forward too.
                  stage 2 vxr
                  [email protected]
                    Yeah i had the same problem with money issues so i decided to save up for the full system and stage 2 remap. Should have it done in a month or 2 [-o<
                      there is a turbo down pipe on ebay
                        not that i have either of these systems but if you are limiting your mods to just an exhaust then try a magnex !
                        according to magnex when dynod it achieved a similar power figure to the full miltek at half the price :wink:
                        regal also use the magnex on their stage 2 so it must do the job
                          Milltek might sound better though. Any 1 know how often the milltek backfires with stage 2 remap??? If it does it every time you lift the throttle or just occasionally???
                            with stage 3 it's popping all the time when cold but not too bad when hot just every now and then sounds great though
                              Hold on there!!!!!!
                              News Flash
                              I have just been into Courtenay web site only to find that Milltek have now released a system like the magnex.
                              It still uses the main CAT.
                              £599 thats cheeper than the Magnex unless you go on EBay as you can get the full Magnex for £567 delivered!!!!!!!!
                              PS Still can't make my mind up either.
