help with gauges???
  • help with gauges???
    I would like to know how you fit a boost gauge and a temp gauge to an astra vxr??
    1. how do you get the vac pipe through to the engine bay ?
    2. how do you connect the lights so they come on with the light switch ?
    3. were do you connect the vac pipe to ?
    4. how do you fit the temp gauge ? and what to ?
    Any addvice would be a help guys ? cheers !
    sorry mate if you already know that - temp you can see on hidden functions on BC
      Where where where??????????
        it is working for Astra and also for Corsa - with running engine or ingnition on just press "SETTINGS" till you don heart beep - than just press BC few times - on BC display you than will see lots of info - as also temp
        thats pics from me corsa:
          Will try that out shortly, cheers buddy
            no problemo amigo
              Not sure if it matters on the corsa, but when on the astra the radio has to be on. Also when you press settings you have to have system on the screen not audio and then hold it in.
              Clique #14
                Get a 3 guage coversion so you have an oil and water temp gauges along with a boost guage sat where the center console vents are. Daz (vxrcourt3) has done mine and a frew others on here and they look like they came factory fitted.
                  yeah think that i saw those pics - great job ! looks awesome !!!
                    Heres mine on the following thread:
                    http://www.vxronline.co.uk/forum/showthread.php?t=27627
                      The problem with this reading is that it only shows the coolant temp. The one that is important is the oil temp and you can't see this anywhere on the BC
                        i dont have the standard radio in anymore! also i need to know how i can get the vac pipe in to the engine bay from inside the car?? and were do you wire the lights to of the gauges so it comes on with the head light switch ?
                          Boost gause is easy so Install
                          connect a T piece to the fuel reg but I dont know how with the Lights sorry
                          boost is like a Dump valve on installing
                            how do i get the vac pipe through to the engine bay,,, is there a hole some were ? behind the glove box or something ?
                              behind the glovebox is a grommet where the main loom runs, i would imagine this is the easist place to feed through, but i dont know if daz uses this point.
                              Whats next?!?!?
