Baffles?
  • Baffles?
    I am really pleased with my VXR and had it 2 months now.
    The only issue I have with it is that once warm if i rev the engine on stand still and take the foot off the accelerator i hear a tinking noise. I also hear it when i switch the engine off from a run (normal run not a ragging the ars* of it run).
    Is normal to have this sound or not (think it could be the baffles in the exhaust)
    Oh it is standard model no mods at all.
    Is it a problem, do i take it back (leased so could be a problem) or what?
    Astra VXR SMD Conversion, a couple of window stickers, front VXR badge and someone stole my rear VX badge!!! TOTALLY PIMPED OUT
    From what i've read on hear, most do this. Mine certainly does.
      what year is it , could be manifold studs??
      Originally posted by soosie
        58 - 2 months old done 3000 miles
          Hmmm might not be manifold studs then
            the ticking after a run could just be the car cooling down
              It is not a continual ticking like cooling it definately is the exhaust when reved on the drive when revs drop off or when switched off from a drive.
              If the exhausts do this then fine but i am concerned it might get worse.
                if you want it louuuud.
                talking about baffles put it the backbox in the freezer then drop it in the morning untill it rattles then Put it on will be loud then
