Silly exhaust question
  • Silly exhaust question
    Has anyone actually got the standard exhaust to pop and bang? or is it impossible?
    Astra VXR SMD Conversion, a couple of window stickers, front VXR badge and someone stole my rear VX badge!!! TOTALLY PIMPED OUT
    Impossiable I believe BUT not too sure.
      i believe it can if you fit a de-cat pipe.
        Bugger !!!!!
          Yes it is possible & yes it it does
            yes but question was standard ( which will mean with cat )
              I know mate, I did read the question
                That's the key
                Astra
                  sorry for the hijack, but is a pre decat pipe any good as i first mod? and does it cause any problems?
                    I read the question and think you mean the standard tailpipe? If so then yes if you buy a pre cat replacement pipe it will pop a bit. Mines does. Nothing like a Remus or non res milltek does though.
                      It is a great cheap mod and gives 8bhp. It will also allow the hot exhaust gases to escape quicker so is better for the car. The car will also pass the mot on emmisions without any problem, so you will not need to put the precat back on.
                      Check this out.
                      Courtenay Sport High Flow 70mm Front pipe
                      The Z20LEH engine is fitted with 2 cats - a pre-cat and a main cat. Our performance front pipe replaces the original restrictive pre-cat. This is only required to be fitted to the vehicle up until the point of 1st registration, as the main cat still ensures the vehicle will meet all MOT emission regulations. The new 70mm front pipe is made in stainless steel, and by smoothing the bend radius and removing the cat, we have dramatically improved the flow through the unit. Our front pipe also features both a stainless steel 3 bolt flange and stainless steel spun end. Our performance front pipe will give a typical increase of around 8 - 10 bhp.
                      Courtenay Sport 70mm Pre-Cat Pipe: £180
                      www.courtenaysport.co.uk
                      for all your tuning needs.....
                      01692 404313.
                        Only thing to consider is will you end up buying the full system as usually it probably makes more sense to buy the whole system as one
                        Astra
                          Yes....i believe Tom Chilton did at the VXR Trackdays once
                          My VXR from Start to Finish
                            Tom Chilton made car after standard car pop, at VXR trackdays. He made drive shaft after drive shaft snap as well. So I guess if you can pop your standard exhaust your going to need a new drive shaft !!!
                              Check this out.
                              will that fit straight on a standard size pipe (will it just bolt on!!)
