has anyone tested the max bhp the oe turbo can take?
  • has anyone tested the max bhp the oe turbo can take?
    anyone?
    You mean, just keep uping the power till it breaks?
      lol i definitely haven't tried that one, i quite like mine in good working order and with a warranty on it!!!!!
        mines at just under 300 and fine.
        Some are 310
        Limit I would say is 320-330 then it goes BANGGGGGGGGGGG
          Sounds like your going to be the Test Pilot Darren
          My VXR from Start to Finish
            NASA used a monkey too
              Some are 310
              I doubt that very much. Percy had a look at the turocharger characteristic maps for the standard KKK units, and 300 BHP is absolutely screaming the knackers off it, in terms of boost and RPM (upwards of 140000-150000 revs). Thats probably why cars make cars make decent figures when first mapped, but then that gradually tail off as the turbos are hammered!
                I do allways like to add that no Astra VXR will make over 300BHP without having uprated fuel injection, the oe is physically not capable of pumping enough fuel to get over 300bhp.
                  where can uprated injectors be purchased from?
                    erm i think Percy is running over 300 bhp on standard fuel system.. he'll correct me if im wrong.
                      vxr-astra-boy is running 300 bhp on standard internals,injectors and turbo and car feels fine even when hammering it
                        percy isnt running standard fuel injection.... ok the injectors are the same, but he has an uprated fuel pump which he popped in himself. He did calculate that the fuel pump was the weakest link before the injectors
                        Burg blood in my veins.... Ice cool Baby!
                        !!Warning a VXR may inspire confidence!! Now for sale
                        http://www.vxronline.co.uk/forum/sho...ds-and-stanced!
                          He never got around to fitting the fuel pump, and with 330 BHP on tap, the fuelling is spot on, he has fitted an AFR gauge to keep an eye on it, and its always spot on.
                          Infact, on the first map, where the car made 365 BHP, the fuelling was spot on. It may well be beyond the specification of the pump, but it delivers.
                            Mate i was running 324bhp with vxr injectors
                              I think the std turbo will make 300bhp but not for long
                              spec'd for 240bhp it will make more but its giving it a hard time ??
                              the truth is out there
                              part GSI part VXR
