HELP Required - Poor radio reception after headunit upgrade
  • HELP Required - Poor radio reception after headunit upgrade
    I have recently upgraded to a pioneer avic-db3, since fitting had a rubbish radio reception.....swapped the aerial for a honda type r one and still no different.....used autoleads connectors first then connects2, then had to have rewired so got temp and time on top display
    is there something else needed? a radio boost lead or something cheers any help appreciated
    sigpic BURG 472 Gone
    pm basilD
    GONE BUT NOT FORGOTTEN!
      Did you buy the farka adaptor?
      Also you need to remove the blue aerial power lead that comes out of the radio, as this doesn't connect to anything in the cars loom.
      You connect this blue lead to the farka adaptor.
        daz vxrcourt3 fitted it..... will have to check with him if i supplied him a farka adapter.....if not were can i get one cheers
          http://www.caraudiodirect.co.uk/fakr...or-p-5632.html
          I installed a Alpine, so the socket on the HU was the other type. So I pulled the banana socket on the fakra adaptor apart and soldiered it straight into the alpine. Neat job. I could of spent another £5 and brought an adaptor.
          You'll notice in the above link a blue lead loose in the picture, this connects to your aerial power output from your HU. The blue/turquoise socket connects to the car and the silver one goes into your aerial socket on your HU Make sure thats the one that fits, or you'll have to buy the adaptor or do a DIY job
            cheers don't think i bought one of them.....will have to get one
              No probs, make sure you read my post again, I edited it, just in case you read it before I finished editing
