astra vxr brakes
  • astra vxr brakes
    hows it goin people? thats my pads just about needing changed so was wondering if its best to change them with just the standard pads or is there a better set of pads to fit? dont know if i will be changing the discs.
    also has anyone got a step by step of how to change the pads? i have a good idea what am doin but would like a step by step guide just to keep me 100% right.
    thanks
    milltek full system with straight throu middle section, courtenay panel filter, re-maped, lowered, 19" alloys,
    EBC Yellow pads would be a nice upgrade
      thanks
      if its your first time changing pads, id just do the pads this time round and upgrade to ebc yellows as mentioned by 'the fi' and next time do both as the yellows are a little rough on the discs
      GONE BUT NOT FORGOTTEN!
        ok so just replace with standard pads and move onto yellows when upgrading the discs?
          upgrade to yellows now if you feel the need for better pads (and discs are ok) and next time round do both
            Get the Yellow stuff pads
              so yellow stuff pads and leave discs standard?
                if your discs dont need changing just now yes
                  thanks, just like to be 100% sure :L anyone got a step by step?
                    how you mean step by step? you mean a guide to changing pads?
                      yeah just a guide to keep me 100% right
                        Mine is the SAME!!!
                        I need to replace mine
                        Im thinking of getting
                        Courts 16G front
                        8G rear with the yellow stuff pads
                          which is better
                          Red pads or Yellow pads
                          Uprated Brake Pads
                          We supply Red Ceramic pads for fast road use, ideal as a good alternative to the OE pad working at up to 550 degrees C or Yellow ceramic pads which work at higher temperatures than the Red pads for more spirited driving on road driving and light track work (e.g. trackdays). Available for Front and Rear.
                          Red Pads - Yellow Pads
                          REMEMBER ITS MY DRIVING HARD AND FAST...
                            ORRRRRRRRRRRrr
                            Is it the Courts section or this for 499 on Ebay
                            http://cgi.ebay.co.uk/VAUXHALL-ASTRA...1%7C240%3A1318
                            What is the difference
                              I brought Yellow, cant fault them, they're superb. If I put the standard ones back now I'll probably think I've lost all my brakes, that's how much of a difference they make.
                              I need to re inspect the drivers side though, the pad is only touching about 3" of the disk, the other 2" isn't touching!!
