cool stat fitting
  • cool stat fitting
    ok worked out with the help of vxrdave where the cool stat housing is sited, its held on with a few nuts etc, ok one question though one of the coolant hoses obviously comes directly off the housing. Does this mean in order to swap the stat over you have to drain the coolant liquid again as i did to fit the coolant hoses in the first place. then simply swap them over and put back
    Re: cool stat fitting
    is there no where you can take it to get it done?
    i`d hate to see you knacker your car
      thay will be coolant in the block so some will need to be drained out not all of it just so its below the stat just two bolts holed it on and the two pipes
        ok well think ill drain whole system, is it easy from then on just undo nuts on housing. what bout small black pipe that attaches to housing
          how does the actual stat come out and go in is it a twit in/out
            push down and twist.
