spray
  • spray
    Whats the best thing to spray your engine parts with to change colour
    Very High Temperature Paint.
    I see dumb people.......
    .....they're everywhere
      Depends what you want to spray, metal, plastic or the rubber hoses? Each would require a different spray i believe due to the surface it has to bond with.
        Hi Chris, any spray will do UNLESS the bits you want doing are heat sensitive, then you will need to use temperature resisant one which will withstand the temps, but will need a QUALITY primer which will also take the heat these are harder to obtain than the readily available colour top coat ones......
        WHICH ONE TODAY.... ???
        LAMBORGHINI LP560-4.....VXR8 BATHURST:S...or.....FOCUS RS
          Hi mate hope you enjoyed your days off where can i buy this stuff from
            Halfords i do the hi temp paints, not sure about primer's, try a auto paint supplier for them....
              what colours do you have i want to change my bay but not sure what colour to do it . how much is it . I think one day i should just drop my car off at your house and let you do everything too it
                they will bedifferent shades
                  Frosts auto supplies somewhere in Rochdale.................www.frost.co.uk
                  Son of the Clyde a roaming went
                  Sinned aplenty, much to repent
                  loved and lost, gave and took
                  Way too lazy to write a book.sigpic
