If turkey noise doesn't go by rehooking the hose.
  • If turkey noise doesn't go by rehooking the hose.
    Hello,
    My Turkey noise didn't go after the hose was rehooked, finally the problem was this:
    Field Remedy: 2131
    Models:
    Zafira 2001...2004,Zafira-B 2005...,Astra-H 2004...,Astra-G 2001...2006,VX220 2003...2006,Speedster 2003...2006
    Engines:
    Z20LET,Z20LEH| Z20LEL| Z20LER,Z20LEL| Z20LER| Z20LEH,Z20LET,Z20LET,Z20LET
    Complaint:
    Whistling noise during deceleration.
    Cause:
    Delayed function of the bypass valve of the turbo charger due to:<*1*>- wrong mounted vacuum tank from previous repairs<*2*>- vacuum tank (below intake manifold): check valve defect, decrease of vacuum<*3*>- vacuum pipes (polyamid pipe and hoses) leaky/defect<*4*>- switching valve (mounted beside tank) defect<*5*>- compressor bypass valve defect
    Remedy:
    In case of customer complaint check vacuum tank and lines for correct
    mounting. The mark "TOP" on the vacuum tank shows in this application
    downwards. The correct mounting position is important because of the
    check valve inside the vacuum tank.
    It is possible to check all valves and vacuum pipes with a Kent Moore
    hand pump.
    If vacuucm doesnآ´t decrease the tested component is OK.
    Note: In case of complaint refer also to Quick Information 2259.
    FunctionalGroup: J - Engine
    Complaint Group: 14 - Noises or Vibrations
    Trouble Code: None
    FD
    I will be asking the dealers to check it for that Field Remedy number when it goes in for the manifold studs - I have previously had it checked for 2259 and had the diaphragm changed then.
    Astra
      So is that saying the word TOP on the vacuum tank has to be downwards going against how it is marked....???
      As mine was like this and i turned it around and made no difference.?
      WHICH ONE TODAY.... ???
      LAMBORGHINI LP560-4.....VXR8 BATHURST:S...or.....FOCUS RS
        I read it like that as well - Hmm?
        Astra
          thats in cause section so that would be whats causing it
            first the hose came off mine, Daz kindly put it back on problem solved for a while then valve split.......then upgraded to regal diverter valve this solved mine
            sigpic BURG 472 Gone
              Hello everyone
              I have had my vacuum pipe come off twice and wanted to know the bes tfix other than replacing the hose with another brand.
              Do cable ties work? I do not want to glue anything...........
              Other ideas appreciated. I think GM should fix this properly.
              cheers
              Ice
                Also interested in regal diveter.....any info appreciated.
                cheers
                ice
                  I have my hoses attached with cable-ties, not had them come off yet. However, I still had the turkey gobble even after having the diaphram replaced.
                  The solution to my Turkey Gobble was to fit the Regal Diverter Valve. Problem solved and the turkey has never come back!! The product is great and is alot smoother than the OE. Had a similar product on my previous car (Audi TT) which is why I went with this product as I knew it was a good piece of kit and the company that has developed it for Regal are well known in the Porsche and Audi community....
                    Originally posted by FreshDriver View Post
                    Hello,
                    Field Remedy: 2131
                    Models:
                    Engines:
                    Complaint:
                    Cause:
                    Remedy:
                    hand pump.
                    Trouble Code: None
                    FD
                    Cheers matey,
                    Took my car in today armed with the 2131 field remedy and they were quickly able to tell that this was indeed the problem, so got it booked in for monday to get sorted as I dont have time today
                      Thats great! I would like to get my hands on a regal valve, but I am in Oz. Anyone know if they have dealer over here?
                      I will use some cable ties on the pipes to stop them coming off.
                      I would also like to know if someone can post field remedy 2259?
                      I guess what I am interested in is how many of these stock valves fail as my whole turbo was replaced last year at only 1500k's on the clock.
                      ice
                        now with this noise, is it every time you take your foot off the loud pedal?
                          Everytime you lift off and the car is on boost
                            Surely when you lift off....the car isnt on boost anymore ha ha
                            sigpicUse to have Astra VXR ST2(courtenay Sport ) 281bhp & 323lb/ft
                            Gotta L200 4x4 now....Mental
                            Who is up for a spot of Offroading
                              You know what I mean, smarty pants
