Removing the Cat
  • Removing the Cat
    Right I was thinking. Is it easy to remove a Cat the main cat on a remus Exchaust
    I know it will fail MOT. but will it make proformance even better and it louder..
    Then come MOT time which is 2 and half years get them to Bolt it back in
    Surely you will need a map that allows for no cats as the lamba readings will be out and flag the emissions light up on the dash?
      I would have thought so
      Astra
        ooo I didnt think of that lol
          there is a map on regals ipf unit for no cats.
            might not have to worry about it i know of someone on here that runs a decat on his zaffie with no lights coming on and he's running cs3
              it is possible BUT your warning light will constantly be on due to the removal of the lamda sensor
                decat pipe the Astra got 2 cats I want both gone
                  the pre cat you can decat as all decat precats can use the first lambda sensor however the main cat also has a lambda sensor but by removing the cat it will tell the ecu something is wrong hence the wrning lights,really not worth the trouble mate,just keep the 100 cell cat your burg has
                    nope lamda sensor still in pipe and No lights on has made no difference
                      have you got straight through mate,no cat?
                        not me but some one else on here has with a cs3 zaffie has had no cat fitted and no warning lights
                          let me get this right , from what i read it`s an mot failure so by doing this surely it would effect your insurance aswell, is this correct ?
                            Thats a very interesting point that im certain not many have thought about. As it would fail an MOT it is then deemed to be un-roadworthy and would therefore void insurance!
                            Good point mate
                              it's only a mot failure if it fails the emissions test if it don't then it won't fail
                              it's not a fail just cos it an't fitted
