My first test drive and a question
  • My first test drive and a question
    Hi,
    I had my first test drive of an 08 VXR astra in Arden Blue 2 days ago.
    I noticed if I accelerated hard but almot instantly backed off the accelerator I could hear what sounded like wastegate chatter.
    Is this normal on a standard car or could this car of been modified?
    The test drive was at a main dealer not private.
    Darren
    Welcome mate, no its not 'normal' do a search for turkey noise, then all will become clear.... its basically some disconencted vacuum pipes in a lot of the cases, otherwise could be recirc valve, the threads you come across in your search will highlight the common culprits
    Cheers,
      Thanks alot, from reading the other posts it sounds like it was that turkey noise as you said.
        There is a recirc valve noise btw, which is normal.
          As said, it's not normal... BUT you don't have to worry. It's just a small pipe come off, and it's a common problem.
          Mine doesn't have the issue though, if you are worried! Could buy mine!
            Pulse, I may take you up on that offer if my car sells quick enough!!
