Blow off valve
  • Blow off valve
    hey guys i know a bit about the d-valves and that available for the astra vxr, but i was wondering has anyone got any info about the blow off valves on the market there are a few forge blow off valves on ebay etc, i heard alot of dodgey things about these,
    now i know alot of people may write in this thread dont get dump valve etc, they do nothing, etc i know this but just wondering any info on the BOV etc? thanks peeps .
    DV and BOV are the same
    Depends what you like
    Some slow car down
    some are louder than others
    If you want the best sounding one its the HKS SSQV which is amazing on a astra vxr b ut needs alot of work to make it work
    Next is the Forge then the Baileys is a slight pssst noise if u want people knowing that you got a turbo car
      Some slow car down
      Define extra work?
      Clique #14
        Do people rate the Baileys DV or not, how do you fit them and how much do they cost? I like the subtle sound on the VXR from standard but wish there was a little more to it.
          well i got a baileys and its good imo i like the subtle noise when you back off the throttle and i haven't found any problems with it at all touch wood lol. As for cost they are going on ebay for £120 for the twin piston one that you need for it to work and for fitting dazturbo6502 has done a how to on it.
          http://www.vxronline.co.uk/forum/sho...ht=dump+valves
          hope this helps
            i had one, not worth it, sound ****. save your money and put it towards somethin with you will gain more from, like the whiteline rarb, or plugs and filter.
            can fit it with this, go down to dump valve..
            http://www.courtenaysport.co.uk/inde...ewDoc&docId=93
            or this pipe
            Dump Valve Take Off Hose 2.0 Turbo
            http://www.courtenaysport.co.uk/inde...ewDoc&docId=20
