Condensation Again !!!
  • Condensation Again !!!
    Really frustrated by this one spoils the whole car !!!
    Both rears misted most of the time now with the weather we are having, well constantly bad, however does not seem to affect other marques out there. I just wished there was a definitive answer ???
    As stated previously my 06 VXR never had this issue at all ???
    Any solutions to this yet from anyone, VXL , maybe???
    my rear lights have misted up and fronts but after a warm up of the engine in morning mine disspears i aint to bothered by it and i got a 57 reg
    Arden Racing Edition
      my burgs rear lights the same
        same with my burg rears too, even the front lenses at the bottom corner .. fookin weather
          there are differnet seals for the lights and can be done under warrenty but you have to show your dealship and they decide weather this is normal or abnormal, as the lights are breathable and can do this to a small extent
          Modified seal for rear lights OS/NS 93183069 (to solve condensation problems).
            how much are they? think i will just do it my self
              don't know the cost mate but i cant imagine it will be much they are just seals
                yeah i guess, will try to get some does my head in that they mist up, no other car i have had has done this
                  try and get it on warranty, take some photo's when it is really bad so that when you go to the dealers if it is gone you can just show them the pics, no point in paying for it if you don't need to, plus if you do it yourself you will need to take the lights off and dry them out will take a while to do it properly
                    well i did take the car to a dealer in ull when i was up in Yorkshire last time and they said they couldnt do anything unless they where holding water
                      Got a 58 plate and mine mist up.
                      Astra VXR SMD Conversion, a couple of window stickers, front VXR badge and someone stole my rear VX badge!!! TOTALLY PIMPED OUT
                        Same here, 58 reg burg always misted up
                          just taken mine into the garage for :-
                          - lights misted up
                          - replace the sagging leather
                          - rattle from exhaust at low revs
                          - door card doesnt quite fit around the window
                          - horn doesnt work when lights are on
                          - wheel wobble
                          and they didnt have enough room on the job sheet to put everything down, haha
                          INSIGNIA VXR
                            tried tightening the rear covers? there are some adjusters on the top leading edge of the rears if i remember correctly that ensure they are flush... Also check your seals. I silicon sealed my SRi's front lights at the inner corners because there was a slight gap. Astras are notorious for this though...
                            #ImKindOfABigThingAroundHere
                            #IHaveManyLeatherBoundBooks
                              same here 58 vxr, front afl and rears mist up, but clear when on... may look at fixing them myself, had to do this in the past with some clio rear lights
