Question about IC/ stage 3 map
  • Question about IC/ stage 3 map
    Right not sure which way round i will do this.....
    if i get the stage 3 remap ( on sport button mode ) am i alright to drive the vxr for a couple of days without the intercooler fitted, i wnt be using the sport button mode so technically wont be using stage 3
    or
    if i get the intercooler fitted first then a few days later get the map will the intercooler on stage 2 make a power gain/difference?
    Create your own banner at mybannermaker.com!
    Im no tuner but if you got the map on the sports button and didnt switch it on i couldnt see the problem. And i couldnt see the problem with having the intercooler put on whilst you have stage 2, dont know what gains etc you would get theough
      You'd probably be fine at this time of year as the air is already cold, but I wouldn't want to cane it straight from traffic for example, the engine heat soak would mean the intake air was a bit hot.
        Dont use full throttle for more then 5 secs
          For gods sake dont get this thread going like the one in the other forum.
              Originally posted by smokinvxr View Post
              mite be coming down to u soon.. me, the vxr and the intercooler.........in the boot! if the offer to help fit it is still available pal
                no probs mate have you got the longer brackets to hold the air con rad to the coolant rad?? should have 2 of them or 3
                  will find out when it arrives... mite be a while tho bein xmas
                    no probs even if you haven't they can be made easy enough
                      lol
                        dont know about other maps but EDS ones have multi-levels of tuning in them, if a sensor shows as being out of range the ecu switches to a different mappinbg to protect the engine (commonly known as ignition pull back or retardation)
                        You will ok for suure, as John mentioned a few posts back, at this time of year you will be OK to last it as the air intakes will be nice and cold, dont worry about blasting for x seconds, just do it and have fun
