bluefin info
  • bluefin info
    is it possible to get the bluefin with a stage 1 map for the astra an the stage 1 map for the corsa.im thinking that if i was to get 1 then i could map the astra an the artic with the 1 unit if you know wat i mean.im sure john would be able to help me out on this 1 as i would be buying from thorney
    and maybe re-map half the forums cars aswell pal-this does not happen one map for one car matey
      it did sound to good to be true.would i have to buy the other map from thorney if i already had the blufin.if this was the case the map would surely be cheaper though
        unit will only work on the one car unless you get it re-set which costs about £250 i think
