this fit the vxr???
  • this fit the vxr???
    http://www.mathijssentechnics.nl/indexx.php?t=2
    The astra VXR engine is the Z20LEH isnt it?????????/
      sorry click power caps and pipes
      then the top 1.9 setup
        You mean this:
        If so then yes as that is the 1.9CDTI airbox coversion that Percy does, and has been doing so for some time.
          yep that
            If i remember rightly, VXRDean has a 1.9 CDTi air box fitted to his
              Yup - supplied by Percy
              Astra
                So LET stuff does fit LEH then???
                #ImKindOfABigThingAroundHere
                #IHaveManyLeatherBoundBooks
                  the maf on the let and leh arnt the same....vxr set up is larger so that must include a larger maf for the let
                    i like the dump valve set up out the top hat though 299 seems steep
                      what did percy charge?
                        I just ordered my kit from percy and get it in jan 13th around I think
                        Percy is relally good at it and everything just speak to him
                          that kit is only for the 70mm afm cars (z20let,ler and lel) it wont fit the 80mm afm on vxr.
                          ...superior horsepower through knowledge,good design and maximum efficiency
                            Not trying to bow smoke up my mates **** or anything, but I got my airbox kit off Percy a couple of weeks ago, I was instantly impressed on how much more responsive the car felt, but put it down to the fact that it was quite a bit colder than it had been....
                            to cut a long story short, the car had to go back to the dealers, so I put the OE airbox and crossover pipe back on, straight away I could tell that the car didnt have the same pull as it did with the CDTi airbox on, and how much quieter it was Suffice to say that the airbox is going back in tomorrow, and is worth every penny!
                            I quite often joke with Percy about his performance mods (Triple P - sort of Triple 8 meets Prodrive Performance Packages) but they definitely do work. Not sure how many other people have built their own Garrett turbo conversions???
                              percy stuff looks the dogs danglees just looking at pics you can see its top notch its next on my list
