dash hawk
  • dash hawk
    im going to florida in a few weeks and was interested in a dash hawk.
    http://cgi.ebay.com/ebaymotors/MSD-1...1%7C240%3A1318
    it doesnt list my car but it says it works with canbus so i presume it is ok. i would just like some clarification of this and is this the type to go for. i should be buying it in mid jan..
    many thanks edd
    Should do mate
      check here :-
      http://www.courtenaysport.co.uk/inde...&productId=170
      or
      http://www.dashhawk.eu/
      Originally posted by soosie
        i know that vxr-wayne has one in his corsa , so should work fine in the astra
          yea it will work fine
            you picking one up or two?? LOL!
              what are theyt mainly used for? main features not all the little ****** features
                loads of different engine values and other values as well
                iive even heard you can personalise them to include shift lights, so if you wanna change at 4500rpm every time, set it to this and then theres a light comes on to tell you exactly the point to change
                Whats next?!?!?
                  wow thts cool
                    there good bits of kit, no doubt
                    i believe they take all their reading from the ecu on the car, so you get pretty much evrything the ecu reads, its just whether the software on the unit is compatable with your car.
                    I think the only thing it doesnt read on the vxr at the moment is boost pressure
                    Whats next?!?!?
                      Thats right, i have a scangaugeII, which is a great bit of kit, but it also does not read MAP/boost pressure although available to select, what we need it someone in the Astra/VXR community to figure out the unique method that the canbus system/ecu uses to report MAP (Boost), if someone could capture the signals that are being sent from the MAP sensor (it does exist as Tech 2 can read it) we could then programm these devices to ask for it correctly.....
                        do these give water temp and oil temp?
                          lol I could do with this at 6000rpm to remind me to change... havent got used to all the power being at the top end yet lol
                          2008 - 2011 CORSA VXR - ARDEN BLUE - 18"
                          2011 - 2014 Astra SRI CDTI [150] XP + 18"
                          2014 -------- Audi S1, Glacier White + Quattro Exterior + other stuff
                          Originally posted by Flinty
                          as with every old lady, you warm her up before letting her have it
                            everything that the ecu reads this can display, compatability permitting
                            oh behave what are you corsa owners like. Get some torque
                            Whats next?!?!?
                              Ive had one a about 2 years now great bit of kit and the shift lights a great. Reads and clears the codes as well.
