How can you tell if ECU reset
  • How can you tell if ECU reset
    Hello there Im runnign stage 3 296 bhp and it just realllly dont feel like it the past week just feeels soooooo slugggish
    I use only Vpower from shell 99 oct
    My car was booked in to vauxhall for rear breaks is there a way which I can tell if they reset the ECU or upgraded ECU or something
    any other ways
    Just relallly dont feel 296 feels standard
    rolling road??
      is that the only way
        they dont reset them they update then via tech 2 i doubt they did that when they was looking at your brakes......
          dont know about that pal. when my corsa went in for some brake noise they did a software update on the ECU.
          Tech2 Diagnostics
            they could have easily done it when they had the car, i would call them and ask and if they did any decent tuner will re - do the map for you
              how would they know if they touched the ECU or not only the machinic will know and he does about 30 cars a day he wont remember
                ifs theres a update fine but the guy would have had a poke around test drive rubbed his chin.....be lucky if they took his wheel off they wont even replace his saggy seat as it modded i doubt they would re flash his ecu
                  are you sure its not just you thinking its sluggish because your now used to the power? drive a 1.2 corsa about for a week or so then go back into the vxr
                    lol
                    I put on sport and off and it feels the same :S shouldnt
                      some people have had this before take the battery off for ten mins it resets the learning values or somthing might work
                        will I loose the map on the ECU
                          no mate
                            to d/c is and then restart it ... but that means i loose time and date need to insert the OE stero which will b a painnnnnnnnnn
                              be a drive up to courts then as your dealer will charge you at least 75 to tech 2 the car.....good luck
