need new brake pads !!
  • need new brake pads !!
    Evening all, after my recent service i've been told i am going to need my 1st set of new pads in the very near future i am just wondering what the best type to go for is.
    i was wanting some performance ones i.e. green stuff but just wondering what other people have used and if any one can recommend anything and were to get them.
    i've just fitted yellow stuff pads to mine and they are great £80 for pads all tuners will have them
      Yellow stuff are the best for normal to fast road driving
      http://www.courtenaysport.co.uk/inde...&productId=236
        cheers guys what is the difference between green and yellow just the use, and a m8 just told me ferrado are best but more expensive do you know if this is true
          Forrado are very good, used to work very near to where they made them, really stank!
          Green stuff are for normal every day driving
          Yellow stuff are for normal driving, fast road, light track driving
          Red stuff are for light to heavy track use
            Yellows are the top spec heavy track pads!!
            Reds are fast road light track use!!
            Originally posted by soosie
              how many miles have you done ?
                from 1 of my previous posts on EBC brake pads :-
                Greenstuff:-
                Premium street sport pad for cars up to 200bhp. General spirited street driving.Designed for premium street driving offering better brake effect up to 600°C (1100°F). EBC Greenstuff has a high initial brake effect and gives drivers confidence from first application of the brake pedal. The EBC pad creates less dust and the dust is more easily washed off than most brands.
                RedStuff:-
                Superstreet formula for cars above 200bhp and fastest street driving This material is a Kevlar® fibre based brake compound enhanced with ceramic particles. If you have previously tried EBC redstuff (pre-ceramic compound) this material is light years ahead. It lasts longer, it brakes better and is quieter. Being a hard wearing pad, bed-in times can be as long as 1000 miles and drivers must be patient until the pad takes up the shape of their disc.This is a truly impressive fast road pad for repeated heavy braking.
                YellowStuff:-
                Ultra high friction pads for race use but perfectly safe for street use. Although a full race material and capable of high temperature use with very good wear life, this new formulation sets a new trend in race type brake pad compounds that can be used on the highway. The “bite” from cold is superb which is uncommon with race materials (normally requiring warm-up) and makes this a pad which can be safely used on both street and track.
                  Whoops, got it the wrong way round then. So why are folks that dont go on a track use yellow stuff pads?
                    I've had Yellows on mine for 2 months now. Superb pads. They do squeal from time to time, but I dont mind that. I do have a worrying problem on the drivers side though, the pad is only rubbing on like 3 quarters of the disk. The left side is fine. Very odd. The pad is seated properly just like the passenger side.
                      Because they work well from cold too.
                        What does the friction face of the pad look like mate?
                          As said above, check the friction face of the pad.
                          YellowStuff had teething problems with the wrong compound being used causing part of the pad to effectively crumble away
                            You mean the foot print of the pad? or whats actually worn on the actual pad?
                              the actual contact face of the pad where it meets the disc
