just fitted boost guage
  • just fitted boost guage
    just fitted my boost guage its on the left hand side of dash. ( if wanted right will have to get connector and more tubing), i removed the glove box and fed it through the rubber gromet by pushing a skewer through. the fed the guage tubing up the door seal. I connected the guage T piece in the blue dv hosing between the pressure regulator and dv. still got bit of tidying to do with it velcro etc to stick it to dash but all is good. only unsure bout how im going to wire it if i want it to light up :?
    Can you see it clearly. Get a pic up soon. Can you not pick up pwr from the glove box light?
      use the power from the sig lighter the wire taped back in the loom is from the ignition so only live with the ingintion on.
        ill try get some pics up i can email some if you give me your address
          just fitted velcro its fine, how do i get the guage to stay in the pod tho, does it have to be glued in
            did it not come with a band that goes around the gauge then in to the pod.
              i used some butle (sp) tape we have at work to secure my gauge into the pod.
                no it didnt mate so annoying anyone got a spare lol,
                  i have do you want it
                    if its for a 52mm guage mate yes that would be very kind of you as i dont want to glue it if i dont have to. shall i pm you my address?
                      Send me a pick wen you can Corsa
