how much
  • how much
    well just taken the bird to the airport and on the way bk i pulled up to get sum fuel, when i walked around the bk of the car i noticed that the bit of black plasic on the bk bumper has come off. so decided to call in at the local opal garage to get a new one.... thinking it was going to be about 5 quid, was i wrong. 20 quid its costing me.... had to sit down when the bloke told me how much....
    after the fuel stop i saw a new astra opc on the bk of a truck, then 20 minutes later another black astra opc went past with a flash of the four ways... first time ive seen one moving with the 19z.. cant believe how nice it looks... put a smile on my face knowing that i have the same car!!! love it...
    cant you get it under warranty cos it cant have been fit correctly if it fell off :?
      I saw one OPC car where the same plastic was missing. Made me wonder about how easy it may be to fall of. When I clean the car I try to check if it isn't fit properly. I just fear people stealing it.
        sandy you should have followed the truck and nicked em off the car i would have
          thought about it after, but it was coming off the slip road as i was doing about 120.
            Not sure which plastic you mean - any pics anyone?
              its the black bit on the lower part of the bk bumper, you have one on each side that are level with the number plate, the right one can be removed for toeing.
                the one on the right comes off... hope this helps
                  Yup understood. Superglue? Or blue tac?
                    i´d go with a glue gun!!!!
                      thought you werent supposed to tow with this car thats why the zorst is in the centre :?
                        think its if u get stuck or somethin like that.if u look in your spare wheel part u have a toeing bolt ring, thats why the plastic bit comes off. well thats what i got told a the dealers...
                          is that not for the front sandy ????? sure i got told that it was not for towing another car ? i could be wrong some 1 clarify this ????
                            its for if someone needs to tow you, ie if your nose first into a ditch :wink:
                              beat me to arden
