Rear Parking Sensors
  • Rear Parking Sensors
    Do You find that the volume of your parking sensors is quite quiet ???
    If of course you have them fitted ???
    Re: Rear Parking Sensors
    yes they are, surely this can be adjusted by tech2, not that anyone at vauxhall would know how to do it.
      ....go on then what have you hit? :wink:
        Nothing fortunately as long as you remember to turn the audio down !!!
          I must be quite lucky as mine is LOUD :?
            What exactly is Tech2? Software / Hardware? A person? A robot?
            He seems to hold the key to all Astra questions.
              Hmmmmm I wonder if it can be adjusted via Tech 2 !!!
              That would be good !!!
                Basically Tech 2 is the hand held computer/machine that plugs into your car (under the handbrake) and is used for adjustments.
                  Have all Astras got a tech 2 or is it something you have to buy? :?
                    It's a tool which connects to the ODB socket on the car. All VX dealerships have em and it's what's used to check ECU for error codes and fault diagnostics. Can't buy one but you can get other diags which will connect to the port
                      You can also program various settings on your car like Favorite Radio stations and adjusting the volume of the indicator click ...
                      Here's a brief spec/pic....and you can buy it here if you really want to :wink:
                      Cheaper on ebay though.
                      http://www.petroject.com.au/tech2.html
                      Made by Vetronix part of the Bosch Group
                      http://www.vetronix.com/aftermarket/
                      And there's the sales brochure lol
                      http://sbcommerce.vetronix.com/liter...t_tech2pro.pdf
