What type of oil
  • What type of oil
    Hi,
    Wanting advise on the best type of oil and grade to put in. I have had a stage 2 remap done from Thorney last year, and the car is due its 1st service (7500K on clock). Its a bit far to go to thorney for a service, so gona take it to local dealer but i want to supply oil. Also what filter could i supply, and anything else ie plugs etc.......
    I'm running with 10/40 in my car after stage 3
      U would not go far wrong with Vauxhall's own fully Synthetic
      5W 40 I believe !!!
        why is thicker oil better
          I believe there has been some problems with turbo failures and oil leaks when a thin oil is used. !!!
            what about filters?
              Originally posted by Mandy
              what about filters?
              standard long life one should be ok
                5W 40 I believe !!!
                All Vauxhall high performance engines use the above oil now, If ur unsure then the service book will tell you what oil was used when built at the factory
                  5W 40 I believe !!!
                  factory oil was 5w30 fully synthetic(pretty sure)
                    5W 40 I believe !!!
                    YUP 5/30 synthetic , i dont think you can go far wrong wi vauxhall oil and filter myself
                      Thanks guys for the info
                        Just spoke to vauhall dealer where car is going for service ,they said they use semi synthetic 10/40 will this be ok or would i be better with the 5w/40 or 5w/30 :?
                          i ordered the oil for my vxr from vauxhall and they sent the 5/30 which they said the car used
