What exactly is needed to reach 350ps?
  • What exactly is needed to reach 350ps?
    Let's suppose that this long rummored lsd will appear.Our horizon will be wider and the next mountaintop
    will be the 350 mark.Anybody knows if the intercoolers already in the market
    will be enough?Standard turbo won't for sure.Pistons?Rods?Cams?Clutch?
    EDS says pistons are ok,rods no!Any contributions on this ?
    think ull find all after market ics will be fine. should think ull need manifold, turbo, rods and pistons really, uprated software, valve springs possibly oh and some big nbrakes lol
      .........Uprated underwear
        Well, the internals are stronger, so i'd just say...
        IC
        Exhaust
        Free flowing filter
        Remap to suit all mods...
        Larger turbo (T28 - T3 odd size?)
        Rod Bolts
        Larger injectors
        maybe a little head work?
        Cams to give power in line with the larger turbo?
        With a good enough map, i think you'd see 350 with that spec... But that will include some lag due to the larger turbo/IC setup
          Could i go as far as saying that someone could devlop a twin turbo conversion
            four more cylinders....
                IC
                Exhaust
                Free flowing filter
                Rod Bolts
                Larger injectors
                i will do without the lag thanks , my old cossie was a killer for that
                its its just nice to have fairly instant power rather than flooring the throttle and waiting half an hr for the explosion :?
                  No 2 more.
                  Z28NET
                  EDS map
                  Exhaust
                  Bigger turbo
                    Originally posted by alex_c
                    No 2 more.
                    Z28NET
                    EDS map
                    Exhaust
                    Bigger turbo
                    still got to make up another 10bhp
                    hmmmm
                    rear seats folded down, empty glove box and a nice wax job
                      No 2 more.
                      Z28NET
                      EDS map
                      Exhaust
                      Bigger turbo
                      hmmmm
                      plus inflate the tyres to 40psi
                        plus 10 quid worth of high octane fuel and a VXR8 badge on the back
                          No 2 more.
                          Z28NET
                          EDS map
                          Exhaust
                          Bigger turbo
                          hmmmm
                          or go Stage 3.....Only Half a tank of gas, toilet break before driving off and full aero package (take the aerial off) ..... :wink:
                            fit a hose kit from CS, a TMS cooler, Regal power pipe from a Z20LET, VXR badge in seats
                            then change it all over to some one elses bits
                              but then it will be a VXR500 destroyer and Chris will
