Clear lacquer and touch up pencil
  • Clear lacquer and touch up pencil
    Just about to apply the above products to my hardon blue with a toothpick. Just wondering which one do i put on first and how many coats
    Noy sure for Harmon Kardon Blue...
      Apply the blue before the clearcoat as per normal paintjob....
      I would say on the red allow a bubble 25% larger than hole as will shrink when dried so therefore i would put a fine amount on end of toothpick and just touch surface chip nibbing until hole is blue as you must not fill until you apply the clearcoat......
      Just have patience and dont blob it on.......
        Cheers marc i'll dab the blue on first. Do i wait for it to dry before i put the laquer on.
          Oh god yes!!!!!!!!!!!!!!!!!!!!!!!!
          Just dab gently wait 12 hrs then dab on laquer to fill top of chip but PATIENCE is the word ....You only get one shot!!!! :wink:
            cheers marc. I am a touch up virgin as u can tell. :wink:
              Marc, I,ve followed your instructions and it looks a lot better (not perfect though). Can I repeat the process again or do I have to leave it as it needs a bit more.
                Are you saying that the hole is not filled to the top as if so add a touch more laquer when dry....
                  Yeh it needs filling a bit mate. I'll tap a little bit of laquer on tomorrow. I'll try to use a little more touch up stick with the others. I am doing one at a time.
