Rev Counter
  • Rev Counter
    Does anybody elses rev needle wobble up and down at idle?
    The engine note is fine and running smooth. The needle seems all over the place?
    Wierd.
    How much deviation is occuring
      200 rpm ish i think. Not a whole notch anyway.
        When hot or cold?
          er hot. half way to peterborough i noticed. will check if it does it cold.
          its not the engine anyway.
            I'll check mine, I take it you don't hear any change in engine revs and it's just the needle 'bouncing'
              yeah thats about the size of it.
                Intruiging, as said I'll keep watch and let you know, although I don't think is anything to worry about, just tell Mel to stop jumping around in the car and that might help
                  yeah I will tell her to stop it. Silly woman :-)
                    Hmmm...maybe the needle is just excited to be in a VXR? I know I would be if I were a needle!
                      i like it
                        it happens cold, warm and hot
                          have you checked the instant consumption on the computer screen to see if the engine is sucking more fuel?
                          the engine note might be the same but you never know, i checked mine and there is no movement.
                            its a constant 0.1gals.
                            due in for a service soon so will add it to the list along with the dodgy cutout which stops me going through the BC either manuel or on the steering wheel and also the fan which doesnt click into place on feet/face setting.
                              You could put it into test mode and see how much is going through the injectors. Checked mine whilst driving round town a there's no movement normally, slight (as almost unnoticeable) bounce when the Aircon on, which leads to my question - do you have Climate and if so is it on? May explain it....?
