Rear fog lights?
  • Rear fog lights?
    Can the left rear fog light be enabled using Tech2 as I only have the right hand side one activated.
    Is everyone else's like this??
    DAP Stage 2 + extra's
    Don't yer neighbors love the sound of a Remus in the morning.....
    Only the offside one works, not sure if this is a tech2 thing?
      Only one side works on mine, I dont think you can tech 2 it on.
        Ok a few of us in the east of the contry that have the 2008 spec grills also have both the rear fogs working.
        The bulb is in the holder what you need to do is get a small conector that will fit in the multi plug and then bridge wire it in to the light for the other side.
        I'll look in the morning and post how to.
          Thanks Alex, wouldn't mind getting the 2009 spec astra myself :wink:
            i need to do it to the oil burner so i'll take pic and do a proper hoe to and post that and then link to it.
              how to now done here is the Link.
                Excellent Howto!!
                Thanks for this Alex. :P
                Can I ask where you got the wire with the connector on the end from??
                  I put a post about this on Meriva Forum. Might have a look myself and see if it is possible to place a bulb in and simple bridge a wire across to the new bulb.
                    Originally posted by Howell
                    Excellent Howto!!
                    I'll edit the how to so tell you but for now
                    Some of you might have on in the shed or garage.
                    If any of you have ever changed the std radio in an older cat the new one might have came with a ISO conector block that you dont always use.
                    i just used the craft knife and cut it up to expose one of the conetors.
