OMG tyre pressures
  • OMG tyre pressures
    Just covered 1k miles so thought i'd check my tyre pressures. The front were 27psi on one and 48 psi on the other. Cant believe u can pick up a new car with so indifferent tyre pressures on the front tyres.
    mine varies greatly week on week... think it depends on the heat of the day and tyre temp
      Dont forget to check your tyre pressure when the tyres are cold.
      Checking them when hot can put upto 5psi on each one !
        Cheers is it 35 psi all round when cold on the 19's
          If you can find a place, get your tyres filled with Nitrogen...
          Less susceptible to fluctuations because it does not contain water vapour that is found in normal compressed air which expands and contracts with heat.
            Demon tweeks used to do it
            Not seen many places that do.
            I belive that touring cars also run on it.
              I put 35 on the fronts and 33 on the rear.
                I think you'll find most professional race outfits use it
                  Cheers for the info.
                    MY dealer told me to use 33 psi all the way around with the 19's
                      theres a place in st albans that does it heres a e-bay link for it
                      http://cgi.ebay.co.uk/NITROGEN-TYRE-...QQcmdZViewItem
                        One of the first things I do when I collect a new car is to check the tyre pressures.
                        It`s a bit boring, I know, but dealers aren`t exactly renowned for their attention to detail in this particular area.............
                          35psi front
                          32psi rear
                          Always refer to your handbook.
                          Andy
                            Im running 38 all round
                            Opps
                              hand book says 2.4bar
