Long brake travel - advice please
  • Long brake travel - advice please
    Hi All,
    The brake pedal travel on my car is a lot longer than on the others in the fleet. It stops in the end, but just feels mushy!! Needless to say the dealer seems to think it's OK so long as it stops - but it certainly slows down the braking "moment" which can be a bit of a distance.
    Any ideas what's wrong and what could be done before I go up the back of a bus?
    i would request a fluid check/change and see if this helps
      Pads? Fluid?
      tbh, im not overall keen on the VXR brake pedal, i agree its not very firm and travels quite a way, similar to my corsa, and even though thats got big brakes, it still doesn't inspire confidence...
      If your ABS comes on easily over un-even surface, good chance its your pads (lum di dooooo, NOT that we've got that at all ).
        Id bleed the brake system or/and as alex_c said change the fluid, get it seen to ASAP.
