1st Service Problems
  • 1st Service Problems
    Just had my first service and although no major problems one of the brack discs is badly scored. I have only done 11,000 miles and its not been on the track or driven too hard. Obviously this isnt covered by warrenty but there must be a problem for one disc to be in such bad condition so soon. Any advice to potential causes.
    Also had an oil leak on the turbo but all covered by warrenty.
    I had the same problem with the brake disk on my old tigra. I took the pads off and found that there was some dirt stuck between the pad and disk so it started to eat at the disk.
      hi ben no prob's with the disc's but i also had a leaking turbo a lot as to do with the grade of oil used as it's too thin did they put the 5/30 back in for you ?
        Hi mate had my car in to the stealers for the same thing thay tryed it on to start with, by saying i could be crap thats been picked up in the pads but as i told them i had the pads out and it was down to what looked like big bits of brass in the pad thay changed all 4 disks and pads.
