is it safe enough to
  • is it safe enough to
    put the back wheels on the front and the front on the back, as back have a little more grip. :?
    as long as the wheels are the same size, shouldn't be a problem.
      yeah got 19s all round, all the same from factory
        Then no problem....
          thanky
            Best to keep your better tyres on the rear though.
              Yeah, only read on here few months back someone changed them round then hit water on motorway and the rear aquaplained and spun out at speed. Got away with it tho if i remember correctly.
                I suppose the proper answer is to replace the problem tyres
                  Should always have the best tread on the rear :wink:
                    Have you check the tire pressure since you swapped them?
                    | Find | Watch | Follow |
                      all tyres have enough tread, even front just an idea, ill check the pressures tho
                        I found that after 10K miles the front pressures had dropped by 12psi on the fronts - and yes I should've checked before and always do now every 1K miles
                          Are the pressures (from manual) diffrent front & back?
                          I.e. you could be running to higher pressure on the rear, and to lower on the front.
                            34 psi all round 2.4.bar
                              Thought it was 35 psi all round - what my manual says, but that's the 18's
