Help More Dump Valve Questions, Spring Bit
  • Help More Dump Valve Questions, Spring Bit
    Ok I've got my Baileys DV36 and fitting kit here today, ONt he fitting instruction it talks about removing a spring froma diaphragm and putting in a little metal pipe thats supplied. "It states it keept he standard bypass shut so the new dv works"??
    I dont need to do this do i??
    Mine just a case of taping the fuel reg and per pic and cutting the boost pipe and installing the DV
    Please confirm for me
    thanks
    Char
    when i did mine i just tapped into regulator, and fitted bv to courts pipe
      Looking at the fitting kit instruction that come with it dappy Char didnt notice they siad for older astra turbo, Not the VXr im gonna kick her now
      Neil
        Originally posted by CharVXR
        Looking at the fitting kit instruction that come with it dappy Char didnt notice they siad for older astra turbo, Not the VXR im gonna kick her now
        Neil
        Yeah that all sounded a bit complicated, if you buy the courts one, it's dead straight forward to fit, esp if you go for courts pipe too. Tap, screw, sorted!
