Is the astra 2 wheel drive ??
Re: Is the astra 2 wheel drive ??
Originally posted by probetsi thought the astra vxr was 2 wheel drive but here it says 4 wheel drive
1998cc 16v ECOTEC 4-cylinder turbo
Max. power: 240PS (170kW) @ 5,600 rpm
Max. torque: 320Nm (236 lb.ft.) @ 2,400 rpm
Bore/stroke: 86/86mm
Compression ratio: 8.8:1
Max. turbo boost pressure: 1.2 bar
TRANSMISSION
Front wheel drive, six-speed close-ratio manual
PERFORMANCE (manufacturer’s figures)
0-60mph (secs): 6.2
Top Speed: 152mph
It does say 4 cylinder which is in regard to the engine configuration if thats whats confusing you :wink: .
It also mentions front wheel drive which means 2WD.
