service time
  • service time
    need new front disks and pads currenty got MTEC disks on the front, what a good upgrade to go for also
    is the following bits whats best to go for
    5w30 fully synthetic millers nano drive + filter
    standard GM plugs
    any other recomendations ?
    I'd change the pollen filter too you would be surprised how clogged up they get
    Take the two rubber caps of the front strut housings and pack them with grease they will probably be dry as a bone
    It would be a good idea to consider changing the gearbox oil too
      Depending on when the last time it was done:
      Coolant flush and change
      Brake fluid flush and change
      As above, gearbox oil
      Don't forget air filter also (if serviceable)
