Help with a new clutch
  • Help with a new clutch
    Im running a stage 3 and the clutch is slipping.
    what should i buy? Also are the upgraded one a direct change over? To save on labour cost.
    will a light weight flywheel be the way to go over the dual mass? And is that a direct swap?
    thanks
    A standard replacement clutch is more than capable at stage 3. Wether the light weight flywheel is the way to go really depends on what you are wanting to achieve.
      As andrew said standard clutch is fine
      Depends if it's a daily or weekend/track toy with the flywheel
      Standard flywheel is capable at stage 3
      Single mass will free up power slightly but will suffer with more vibration at low revs/idle
      Standard clutch flywheel and csc will set you back £400 at euro car parts if you ask nicely
      Uprated clutch and smf will set you back around 900 from the likes of RnD etc
        Quit informative update on your blog thank you so much for sharing. The people who require the essay writing help uk and the information about cars they have to visit and learn. I just found the cars related updates and these are really excellent thanks for sharing.
