Crankshaft sensor location
  • Crankshaft sensor location
    Hi new here can any one help me locate the crankshaft sensor on my Astra vxr h please
    Its bottom left of the engine block it's on the loom that's runs down the back edge of the upper outer camshaft cover going across the left side of the rocker cover
    Basically easiest way to spot it is it's directly underneath the thermostat housing a few inch below it
    Its held in by a single bolt if you have your replacement sensor you should be able to spot it easily
