Cd30 battery drain
  • Cd30 battery drain
    Can you help my radio is draining my battery is there a fix with out changing the radio and display
    Take fuses 35 & 36 out. You just won’t have a screen or radio.
    that’s you’re only fix. I’m speaking from experience as it took me over a year to locate the issue and then fix it by replacing both for a cd70 and cid.
      I've removed fuse 35 so still got screen but no radio so drain is 0.30mamp was your radio grundig as there ain't much info
        0.30amps is still too high. I got around 10mA once fixed.
        I don’t think it was grundig, think it was blaupunt but can’t remember.
        take fuse 36 out and you’ll see your drain drop even more.
          I could leave the car for months years ago and it be fine what would be my option s
            Your only option is to replace the screen and head unit.
            I used my issue as an excuse to upgrade to the cd70.
